ecu symptoms
Old Apr 6, 2003 | 09:26 AM
accordtuner's Avatar
accordtuner
Banned
Default ecu symptoms
anyone ever have to replace an ecu? what were sum of the common symptoms?
j
Old Apr 8, 2003 | 04:54 PM
AwwsChwA's Avatar
AwwsChwA
normally there's no specific symptoms for a bad ECU, it will just throw out codes that aren't valid, or it will cause really quirky operation. In fact, Honda ECU's even have a code that means "ECU Faulty". Check the codes you're getting from the ECU, and try swapping your ECU with another one that you know is good.
Old Apr 9, 2003 | 01:03 AM
drift's Avatar
drift
Flaccid Member
usually you'll get a CEL even when the engine isnt running. it's referred to as "self check failure", code 1.
