Help On Ls Into Gsr Swap
Old Aug 15, 2007 | 06:50 PM
kelz2011's Avatar
kelz2011
Default Help On Ls Into Gsr Swap
We wired up the knock and the vtech soleniod, but now we have a few more problems. First How do you wire up the fuel injection harness its a large strech, guessing the LS harness isnt long enough. Then we have no idea where to put this plug - http://s3.photobucket.com/albums/y90...t=DSC07381.jpg another look http://i3.photobucket.com/albums/y90...y/DSC07382.jpg. We know it plugs into this thing on the LS intake manifold http://i3.photobucket.com/albums/y90...y/DSC07383.jpg but where does it go on GSR (Wires are yellow with black stripe, and red with yellow stripe)? Also we found that the LS dosent have some plug going in to some black box directly under the GSR manifold http://i3.photobucket.com/albums/y90...DSC07380-1.jpg. Also how do you wire up the throttle wire because its longer, not only that will the intake fit because the throttle body is lower than the LS. What do you do for these things???????????
Old Aug 15, 2007 | 09:10 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The plug looks like it goes to the EVAP solenoid. Are you using the GSR throttle cable?
We need more information on the swap such as the year of the motors and what OBD harness you are running.
Moved to Engine Swaps.
Old Aug 28, 2007 | 06:49 PM
96gizzy's Avatar
96gizzy
Default wire problem vtec and knock
How did you wire the knock and vtec sensors im having that problem thanks.
