Turbo Specialties INSTALL HELP***
Old Jul 26, 2007 | 06:03 PM
Vettetech81's Avatar
Vettetech81
Default Turbo Specialties INSTALL HELP***
I did a turbo specialties kit install on a friends 2001 Accord 4cycl, I am having issues with it bucking under acceleration and under boost, it runs fine with the charge pipe disconnected... they sent me another MAP unit to try no sucess.. I checked the connections for both the MAP Unit and the Fuel Controller.. the injectors do fire if I ground both circuts ect.. Anyone run into this problem with this kit or similar?
Thanks,
-=Rick
Old Jul 28, 2007 | 08:18 PM
Vettetech81
Ttt
Old Jul 29, 2007 | 10:20 AM
1turbodc2's Avatar
1turbodc2
got boost?
what is your engine management? Sounds to be like u need to get a real stand alone not a piggy back, or FMU... Get either crome/neptune/hondata/Aem ems... go have it tunned correctly.
the way you have it right now, is a good way to have shitty performance and a great way to expire your motor in a quick fashion.
Old Jul 30, 2007 | 07:56 PM
Vettetech81
I agree.. we may have to go this route..
This is what we are running...
http://turbospecialties-race.com/fue.../2Injector.asp
I'm not a fan of the electronics portion of this kit... I orderd a "missing link" to replace the map box... it seems to almost run better with the box removed but still hits a wall under heavier acceleration and looses power.. I just tried it that way to see what happens as I first suspected the map box...
Next I will be checking the fuel pressure and volume.. if that doesn't show something I am thinking we need to go another route with the fuel management..
As I may have said.. the car runs fine with the charge pipe removed... its only under boost.. that we see this problem..
-=Rick
Old Aug 1, 2007 | 07:53 AM
Vettetech81
today I checked the fuel pressure.. and it does run 42 at idle.. 53 off idle.. and if I put 8psi to the regulator I see 80psi.. if I clamp off the return hose to the tank I see about 80psi.. and I seem to have pretty good volume as well..
Any other ideas? I have a missing link on order.. so I am going to try that.. after that I'm not sure.. pretty much out of ideas.. possibly reffer this customer to a tuner shop that can program his factory ecu?
-=Rick
Old Aug 3, 2007 | 11:44 AM
Vettetech81
Today, the missing link arrived.. and I ditched the Map Box and installed it.. WoW this car really runs nice now... much much better...
Thank you for all the suggestions guys!
-=Rick
