Distributor Issue
Old Sep 2, 2007 | 01:14 PM
RavynX's Avatar
RavynX
Default Distributor Issue
Hey all. Long story short, I was driving, got engine code 72 (cylinder 2 misfire). When I was diagnosing it the car stalled and it wouldn't start after that. That's when I found out the following after removing the distributor cap...
http://ravynx.net/integra/pics/repai...sted%20003.jpg
I replaced the cap and rotor, and it was still cranking over but not starting. So here I am now wondering if it's the Ignition Coil or something wrong w/ the parts in the distributor.
I am getting a very very weak spark from the ignition coil. I tested this by connecting one end of an insulated wire to the ignition coil and the other end to a ground on the engine block. It's a weak spark and you have to bring the wire very close to the ground source to get it to spark.
I measured the resistances on the coil, but I have no charts to compare those values to. Would anyone happen to know the resistance #'s for a 2000 Integra GS-R (b18c1) ?
http://ravynx.net/integra/pics/repai...esistances.gif
Old Sep 3, 2007 | 09:06 AM
Accord_Freak's Avatar
Accord_Freak
Think Fast
hi Chris!...
Here some info: Between a+ and b- terminals, resistance should be 6-8 Ohms at 68f or 20C...
Between a+ and coil tower, resistance should be 12 800 - 19 200 Ohms at 68F or 20C...
Hope it help!
Frank
Old Sep 3, 2007 | 09:10 AM
Accord_Freak
Think Fast
I think with your resistance at 0.9 Ohms between a+ and b-, you are under spec. replace the coil ...!
