Where to install these gauge sensors?
Old Jul 31, 2002 | 11:38 PM
CapnMorgan's Avatar
CapnMorgan
Default Where to install these gauge sensors?
Where is the best place to install the oil pressure, and coolant temperature sensors? (GReddy gauges)
thanks in advance
Old Aug 1, 2002 | 01:10 AM
CapnMorgan's Avatar
CapnMorgan
btw this is on a Integra GSR motor.
Old Aug 1, 2002 | 01:43 AM
DSC's Avatar
DSC
Long way from home
Most people put the gauges on the, ah, pillar? Like on the left side of the driver, the part right along the windshield.
Old Aug 1, 2002 | 02:07 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
I'm not familiar with the greddy guage kits, are they mechanical guages or electric? That will determine what kind of placement restrictions you'll face more than anything.
-Harry
AIM: NDcissive
Old Aug 1, 2002 | 08:22 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
For oil pressure, you can either put the GReddy sending unit where your stock one is and run w/o the stock idiot light, or you can tee off the stock sending unit location for both. The bes way is to run a line to a tee mounted on the firewall to isolate it from engine vibration:
Although some tee right off the block:
Teeing right off the block hangs a lot of weight off the back of the block on a pretty small fitting, and with enough vibration, it could snap right off, which you probably wouldn't want.
For water temp, people often install the sensor in the coolant bleed port(if you have a B series). My D16Y8 doesn't have a bleed port, so I elected to use GReddy's 34mm water temp sensor adapter, which splices into your upper radiator hose. I had to switch to larger B series hoses to fit my PWR radiator, so the 34mm adapter fit perfectly. It was too large for my stock hoses.
Old Aug 4, 2002 | 11:14 PM
CapnMorgan's Avatar
CapnMorgan
thanks to those with real answers
where did u tap for the illumination wires?
thanks!
Old Aug 5, 2002 | 12:33 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I just tapped them into my turbo timer harness.
Red - switched 12v
Orange - 12v ignition(I think I used Ig2)
White - 12v lighting(Parking light fuse works okay)
Black - ground
*hybrid
92+ Civic/EL & Del Sol
10
Jan 3, 2006 06:44 PM
madman4you
CRX & Pre 92 Civic
May 1, 2005 03:08 PM
FourthGenHatch
Oct 13, 2003 04:50 PM
