Non to vtec
Old Aug 10, 2002 | 04:56 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Default Non to vtec
I just swapped a d16z6 into my del sol s (d15) and now it won't start. I pulled it out of my del sol si. I did not swap in the harness that goes through the fire wall... Other than that, why won't it start? The fuel pump won't come on, and it won't turn over. I'm running a d16z6 with the p28 ecu. The battery is fine, lights come on, and the dash lights dim when you turn the key, but it doesn't even try to turn over.
Old Aug 11, 2002 | 08:12 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
SOMEONE HELP!!! I know someone has to have an answer! I'm rechecking the grounds today, and I'm going to swap starters...
Old Aug 11, 2002 | 11:18 AM
qtiger's Avatar
qtiger
That happened to me... I forgot to reconnect the ground strap that goes from the valve cover to the front bumper.
Old Aug 11, 2002 | 12:11 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
SOMEONE REPLIED!!!
I redid both engine grounds, and then added a third one. Figured it couldn't hurt. So now my dash lights come on brighter. The fuel pump is coming on, but still no cranking.
Old Aug 11, 2002 | 02:10 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
got it running. Delete the post if you like!
Old Aug 11, 2002 | 07:51 PM
qtiger's Avatar
qtiger
What was wrong?
mbanks21
Apr 6, 2003 12:59 PM
RedRexDX
92+ Civic/EL & Del Sol
23
Jan 29, 2003 09:25 PM
Turbo_Teg
Dec 10, 2002 08:10 PM
jermothedrunk
Oct 30, 2002 09:53 PM
TheRooster
Engine Swaps, Tech & Tuning
Jul 9, 2002 02:22 PM
