VTEC head on a non-VTEC block?
Old Jan 27, 2003 | 02:46 AM
RedRexDX's Avatar
RedRexDX
Stupid Hurts
Default VTEC head on a non-VTEC block?
my 92 DX has the d15b7 in it... stock non vtec. is it possible to wire up an Si or other ECU and VTEC controller, slap a vtec head (off what SOHC motor?) and be on my merry way?
Here is my current setup... iceman intake, strut bar, and dc sport header has not been installed yet.
Old Jan 27, 2003 | 03:24 AM
92b16vx's Avatar
92b16vx
D16Z6 head.Either hard wire to the ecu (from the Z6) or vtec controller.You need the complete upper portion IM/TB/FR and INJEC./EM.Throw in a si tranny and you got a good cheap upgrade.
Old Jan 27, 2003 | 05:00 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
like he said, you'll just need the head, IM, TB, you'll also need ignition wires, and it's just easier to use the z6 dist. Then you can just hook up the ecu, and add the 3 wires for vtec, and you're on your way. This setup should, in theory, get you more power than a z6 because of the compression.
Old Jan 27, 2003 | 05:07 AM
ISP James's Avatar
ISP James
DAMIMRED
won't he need the pistons too??? vtec has different valve clearance
Old Jan 27, 2003 | 09:04 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
no dont need new pistons, and i belive you will need to tap the oil pan
Old Jan 27, 2003 | 09:05 AM
RedRexDX's Avatar
RedRexDX
Stupid Hurts
tap the oil pan? what do yo u mean
ummm how much would this type of "swap" cost?
Old Jan 27, 2003 | 11:17 AM
white lightnin's Avatar
white lightnin
A SOHC Vtec swap is cheap. Just ditch the whole motor.
Old Jan 27, 2003 | 11:51 AM
msilage's Avatar
msilage
Got Boost?
i'm doing the same thing but to my 97 dx, this is what im getting
Complete 1998 D16Y8 5spd Vtec head(64k miles on it) w/ manifold/ injectors, valve cover, AEM adjustable cam gear, Throttle body, all sensors, vtec soleniod, Chikara Black 4-2-1 torque step header, Short Ram air filter w/ Tenzo R air filter (its a package deal)
do i need anything else except the ECU? (got a 98 ex ecu but unfortuanately it is a manual ecu and i have an automatic)
Old Jan 27, 2003 | 12:46 PM
The Bum's Avatar
The Bum
Black people go wooooo
At my local shop, about $650 will get you a complete d16y8 installed.
Old Jan 27, 2003 | 01:02 PM
dantastic's Avatar
dantastic
cx power!
mini-me swap!! wtf do they call it that anyway?
