zc problems need advise
Old Aug 9, 2002 | 09:59 PM
Lemonhead's Avatar
Lemonhead
Default zc problems need advise
zc into 90 si ok.......it's all in, the zc is turning over but not starting I'm not getting spark out of the 89 teg distributer that's on it me and my dad checked it and when we cranked it we had no dwell, with the key on both terminals of the coil/igniter had 12 volts, on the zc manifold there is no atmospheric pressure sensor to hook up to the si wiring harness which has one the wires to the sensor are black with yellow stripe,and blue,also I had to remove the wires from the square connector on the teg distributer to work with the si which is round I'm pretty sure I got it right but is a possibility I didnt any advise I need my car to start so I can drive to work if you have any questions to reply with I will check it out and reply back.....thanx
Old Aug 10, 2002 | 09:58 AM
Lemonhead's Avatar
Lemonhead
Default what's up?
any advise,suggestions,burns something..............
Old Aug 11, 2002 | 11:27 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: what's up?
-- check the ECU fuse. If that's blown, the engine will not start.
-- www.zdyne.com they make an ECU retune specific to the ZC
-- check/replace your ignition coil. It may be blown, grounding out before spark gets to the cap. You can test the coil with a test light.
-- if the CEL is coming on for no apparent reason, alternator/voltage regulator (one unit) may be bad. This can happen when the ignition coil goes bad.
amb
10
Nov 13, 2006 05:26 AM
sick79
CRX & Pre 92 Civic
Jan 13, 2004 10:53 PM
hyperlite
15
Feb 3, 2003 11:58 AM
lude69
20
Dec 5, 2002 04:57 PM
i_drive_a_civic
Engine Swaps, Tech & Tuning
7
Jul 15, 2002 07:31 AM
