bad sensor, code 10
I have gotten a CODE 10, or Intake Air Temperature code. I am not sure if I should replace the sensor or which one is best to get...because, the catch is, I am using a 97 gs-r harness on a b16a2. Should I get the gs-r sensor, or just replace the b16a2 one....I "think" they should plug into the harness fine.
Also, is the IAT located different on the b16a2, then the 97 b18c1. Could that cause a problem. I was told all the sensors match up easy. Guess I thought wrong ......
yairsaenz83
92+ Civic/EL & Del Sol
Feb 22, 2007 08:41 AM
