Post Questions about engine swaps.
Old Aug 12, 2002 | 07:41 PM
Kirby's Avatar
Kirby
Default Post Questions about engine swaps.
Post here if you have any questions concerning engine swaps..
someone sticky this please
Old Aug 13, 2002 | 02:54 PM
POONTANG's Avatar
POONTANG
back like scoliosis
will a zc bolt right into an 88 civic 4dr? do i need anything special? (wiring harnesses, axles, tranny, ecu, mounts.........)
Old Aug 13, 2002 | 07:58 PM
jaje's Avatar
jaje
HC Racer H5
the zc is a dohc d series engine...it bolts right in w/o mounts...the 4 door has the same engine bay...wiring depends on if its mpfi...you'll need an ecu from a 88-89 teg (dohc) or one from a zc
Old Aug 14, 2002 | 09:57 AM
excitid's Avatar
excitid
whats the deal with newer d series engines, are they straight bolt in do they use hydro trans. Does honda even use a cable trans anymore.
Old Aug 14, 2002 | 10:32 AM
jaje's Avatar
jaje
HC Racer H5
I do not know of any current cable trannies...i'd like to know the advantage of the hydro system over a cable unit
with all the lines, master and slave cylinders the hydro system must cost more and increase weight over a cable system
Old Aug 15, 2002 | 05:41 PM
excitid's Avatar
excitid
does the y8 bolt straight in to 4th gen hatches
Old Aug 15, 2002 | 05:58 PM
jaje's Avatar
jaje
HC Racer H5
yes
Old Aug 16, 2002 | 05:10 PM
RiceBoysDream's Avatar
RiceBoysDream
what kinda engine comes ina 86-89 integra? i know its a 1.6l but is it a b16a? i thought the b16a was the 00 honda civic SI motor for us in the US. also will a b18a bolt into a 1st gen teg? or will i have probs, also whats needed?
Old Aug 16, 2002 | 07:06 PM
jaje's Avatar
jaje
HC Racer H5
the brown valve cover was the d16a1 (113hp dohc made from 86-87) and the black valve cover was the d16a3 (118hp dohc made from 88-89)...i belive the mounts are different and it won't bolt in a 88-91 ef chassis only the 84-87 chassis but requires mpfi conversion
Old Aug 16, 2002 | 07:08 PM
SpamRice's Avatar
SpamRice
Will an h22 fit in a EF hatch? :fawk:
