Post Questions about engine swaps.
Old Aug 21, 2002 | 07:27 PM
ISP James's Avatar
ISP James
DAMIMRED
how much do i need to cut and weld to make my shift linkage (b18a1 in a CRX)
Old Aug 27, 2002 | 03:00 PM
excitid's Avatar
excitid
I hate to be a annoying but what month scc was the dpi mpfi conversion covered.
Old Sep 1, 2002 | 12:03 PM
b16spook's Avatar
b16spook
Default b16a into 88-91 hf
when doing a gen1 b16a swap into 88-91 crx, do i need an integra throttle cable?..what other little/big parts other than the complete swap and mounts do i need to make it work........
Old Sep 1, 2002 | 12:32 PM
WhiteRice's Avatar
WhiteRice
Yeppers....teg throttle cable. You have an HF right?? You'll need the spindles from the Si.......help me out here guys....the rotors maybe?? I know there were posts about this on a different thread.
Go ahead and get a new water pump, thermostat, timing belt and all of the other little maintenance stuff like that (gaskets too). those are easy to put on while the engine is still on a stand. If you have the $$ get a clutch and a lightened flywheel too.
Old Sep 4, 2002 | 03:48 PM
b16spook's Avatar
b16spook
Old Sep 10, 2002 | 06:41 AM
excitid's Avatar
excitid
have any of you done this
Old Sep 10, 2002 | 01:59 PM
Sickboy's Avatar
Sickboy
I had to do it when I did my swap. I would recommend buying a harness from HASport. My car runs good but the engine bay looks like crap, and it took me quite a while to do and get right, and I'm an electronics technician by trade. As far as just doing it on a d15, I would say go for it but for the cost of the parts you could probably do a zc or just an Si engine swap.
Rob
Old Sep 10, 2002 | 03:44 PM
91GSR hatch's Avatar
91GSR hatch
MAN WHEN I SWAPPED MY SHOC VTEC FOR A B18C THEY DIDNT GIVE ME MY STOCK MOTOR,TRANNY,OR ECU SO DO I JUST GO GET IT BACK ONE OF MY FRIENDS WANTS IT???
Old Sep 10, 2002 | 04:36 PM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
push it once, its quite simple
Old Sep 10, 2002 | 06:39 PM
excitid's Avatar
excitid
Its your isn't it. How long ago was it and did you even ask what they did with all that stuff when you picked up your car. Better hurry up before they sell it to someone else.
