Post Questions about engine swaps.
Old May 18, 2005 | 07:10 PM
  #191
mgastar's Avatar
mgastar
Default b16a vtec dohc 1st gen into a 90 crx
Hello, I am wondering if anyone knows where i could get a wireing diragram for my engine swap. I was told that the b16 a is almost a direct swap excpet for two electrical wires that need to be added. I also need to find where i can get the correct axels and shift linkage. If anyone could please give me a hand i would appritiate it.
Old May 21, 2005 | 10:05 AM
  #192
JoshJ's Avatar
JoshJ
bang bang.
Alright, I'm planning on buying a GSR swap from H-Motors Online. It says:
B18C 94-97 (GSR) Complete Change Over
Price: $ 3149.00 Plus shipping and handling.
Availability: In stock and ready to go.
- Motor
- Hydraulic Tranny (S80, Y80)
- ECU (P72)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Is that all i need in order to drop it into my 00 civic ex? Also,
1) Will I need to buy a different cat conv?
2) What mounts will I need to swap?
3) I have a Apexi N1, can I still use this or will I need to buy a different cat back?
4) If I were to purchase this motor, should I buy the LSD for the extra $300?
5) What OBD is this motor?
6) Will I need to do any wiring with my 00 Civic EX?
Thats all I can think of now. Ill prolly have more later. Thanks.
Old Jun 7, 2005 | 10:51 AM
  #193
chewacka's Avatar
chewacka
Barquisimeto Type-S
does anybody knows the d16y9 engine's pinout? cause I'm trying to install a safc II into it and the manual doesn't show me the wiring for that engine, thanx
Old Jun 7, 2005 | 03:18 PM
  #194
civicunrest's Avatar
civicunrest
Default Question about b18a1 swap
I put the engine into my 91 civic and need to know if I need the wiring harness that goes to the ECU. I seem to have a lot of wires that do not go anywhere from the wiring harness on the Integra motor.
Thanx's in advance
Old Jun 8, 2005 | 03:49 AM
  #195
shady visions's Avatar
shady visions
Hey, I have a 1990 CRX and I'm trying to put a B series engine in it. The GSR engine is way too expensive for me, so I'm convinced on putting a B series engine in it.
Either this:
http://hmotorsonline.com/shop/sc200...page&item=30002
or this:
http://www.hmotorsonline.com/shop/s...page&item=30004
look good to me. They are both about the price I would pay for the engine/tranny, etc.
What I wanted to know, is, if I get the 88-91, could I convert the clutch from cable to hydro? And if so, is hydraulic a lot better?
Also, what about all of this OBD stuff? Could someone explain it to me and what it meant. If I got the 92-95 engine, how much more work would it take me to put it in and get it running good with my CRX?
By the way, the engine in my CRX now is about shot. My radiator is screwed up so my engine overheats all the time causing me to blow gaskets (I've had to replace all three twice already), and my clutch is horrible. It grabs too late so I'm not used to the shifting and it always slips and my tires spin even in the second to third transition. My overall goal is to turbo my engine.
What I also had planned was a type r fuel system, etc, tuned for my turbo. and some better upgraded internals, mostly for speed/hp, and a better full exhaust. Also a FMIC for looks and performance.
By the way, this car won't be daily driven, mostly track. I've already got a Mustang and a Truck I can drive around daily.
Old Nov 1, 2006 | 03:12 PM
  #196
ant's Avatar
ant
Default 1991 honda civic
91 civicdx to si wireing
Old Dec 16, 2006 | 07:51 AM
  #197
89crxinprogress's Avatar
89crxinprogress
is it possible to pull the just the motor out of a crx and not the tranny or do i have to pull the motor and tranny together...? i would like to leave the tranny in if i can..
Old Dec 16, 2006 | 01:50 PM
  #198
SHUA619CIVICSI's Avatar
SHUA619CIVICSI
1991 CIVIC SI
Im Wanting 2 Put Ether A B16a Or Mostlikey A B18c1 What Will I Need Besides The Engien And Tranny And Witch Should I Do?
retroshark
Accord
2
Aug 28, 2005 04:53 PM
NeedCollegeRide
Accord
6
Jul 11, 2004 12:24 PM
djsonic
92+ Civic/EL & Del Sol
5
Feb 23, 2003 03:36 PM
AzDrag
9
Jun 27, 2002 03:53 PM
