Post Questions about engine swaps.
Old Jun 18, 2003 | 11:34 AM
  #91
91_Hulk_Si's Avatar
91_Hulk_Si
M0der@t0r Assassin
Default 89 Integra ZC 1.6L non V-tec
Does the 89 Integra ZC 1.6L non V-tec bolt right up to the 1991 Honda Civic Si HB trans and engine mounts? Also do the a/c, altenator, and power steering swamp from the stock motor to the ZC? Thanx
Old Jun 18, 2003 | 11:57 AM
  #92
Kai's Avatar
Kai
Rotorphile.
Originally posted by 4thgen91EFhatch
should i get an si tranny and put it on my d15b2 now and also switch to MPFI with the 88-89 teg DOHC ecu?...or should i wait til i get the zc to swap it to manual and MPFI?...thanks
also...what are the stock hp and tq ratings of a DOHC ZC?
If I were in your position, I would do the MPFI conversion now and wait for the swap to change over the transaxle. You don't need to do as much to swap the FI system, plus it would be easier to swap the transaxle when everything is out, so you might as well save it for later.
Factory rating on the Blacktop DOHC ZC is around 129hp/106ft-lbs.
It will probably bolt to the transaxle but definately not to the engine mounts. 86-89 Integras use 84-87 Civic style mounts, not the newer 88+ pattern.
Old Jun 18, 2003 | 09:11 PM
  #93
4thgen91EFhatch's Avatar
4thgen91EFhatch
thanks for replyin man...it's been near a month since i posted...why doesn't anyone ever check this forum?...later
Old Jun 19, 2003 | 07:02 PM
  #94
djsven's Avatar
djsven
hi,
swapping a b18c1 into 88 crx. what tranny is the best setup?
the car is going to be drag only.
Old Jun 19, 2003 | 07:05 PM
  #95
Kai's Avatar
Kai
Rotorphile.
a 92-93 GS-R YS1. Be careful to get the GS-R version, as the RS/LS/GS trasaxle was also a YS1 with different gearing.
Old Jun 20, 2003 | 04:52 AM
  #96
jaje's Avatar
jaje
HC Racer H5
Originally posted by djsven
hi,
there are also factory lsd equipped ys1s floating around that you might wanna keep an eye out for...that much power (torque) in such a light car makes it real easy to lose traction
Old Jun 20, 2003 | 09:17 AM
  #97
d0hcnonvtec's Avatar
d0hcnonvtec
Transplant Motor INC
Originally posted by jaje
yes...you can get a dual core radiator for a civic del sol and adapt it to fit on the ef chassis (dual core has much better cooling capacity than stock ef radiators)...however, though in normal driving most people find you don't even need a different radiator
why won't you just get a fluidyne or PWR or KOYO save your self some time and head ache.
fluidyne: high performance
2605 E. ceder street loacal(909)923-9595
Ontario, CA 91761 toll free(800)358-4396
sribelin@fluidyne.com fax(909)923-9797
ask for Steve Ribelin he'll hook ya up.
Old Jun 20, 2003 | 12:01 PM
  #98
jaje's Avatar
jaje
HC Racer H5
granted this would be better than a dual core but when you can get a new autoparts store dual core for $100 compared to $400-$500 for a nice racing unit...or even get a used dual core for $20 at a junkyard its even cheaper
Old Jun 20, 2003 | 08:15 PM
  #99
awhell's Avatar
awhell
i'm thinking of going with a b20 in my 88 crx dx aside from motor mounts and tranny and axle will there be any other major mods to watch for like cutting or anything else ??
Old Jun 20, 2003 | 11:29 PM
  #100
4thgen91EFhatch
i believe you have to do some bangin on part of the engine bay or whatever...i know you do with the b16 swap...check out hasport.com...later
