Post Questions about engine swaps.
Old Apr 23, 2003 | 04:14 AM
  #81
klowndwarf's Avatar
klowndwarf
DC294GSR:
Hes willing to give me whatever i need as he will be replacing those parts (except maybe the axles I don't know). He says he wants a GSR motor.
We await your comments....
Old Apr 24, 2003 | 08:09 AM
  #82
DC294GSR's Avatar
DC294GSR
How did I get here?
Well I havent done the swap, but i hope to in the near future. I mentioned those things because thats what you will need, stock CRX mounts wont hold a B series.. The shift linkage needs to be shortened most likely to fit the CRX.. The ECU and wiring harness dont match up obviously, different engines..heres what ive found so far..
Axles:
http://app1.hybridgarage.com/store/h...2%2001%20AFAXC
ECU: ..can be done other ways...(e.g. hondata, etc)
http://app1.hybridgarage.com/store/h...2%2001%20Z8487
Wiring Harness for that ECU:
http://app1.hybridgarage.com/store/h...2%2001%20AFVTC
Shift Linkage:
http://app1.hybridgarage.com/store/h...2%2001%20AFBLK
Engine Mounts:
http://app1.hybridgarage.com/store/h...2%2001%200AFB1
If anyone has anything to add to the list or knows a better place to get this stuff, hook us up
Old Apr 27, 2003 | 11:19 PM
  #83
88Cardrex's Avatar
88Cardrex
I'm gettin a B16a head complete, cams,valve cover,sol.,intake,throttle body, what else am I going to need beside mounts and trans to put it into my 88 rex?
Old Apr 27, 2003 | 11:22 PM
  #84
Kai's Avatar
Kai
Rotorphile.
I'm assuming you already have a complete block to go with that head. You'll need axles, a timing belt, an ECU, and possibly a wiring conversion depending on the model of your CRX. There was a really good write-up on ALL the things you need a while ago.
Old Apr 28, 2003 | 03:44 AM
  #85
dicivicHB's Avatar
dicivicHB
...on Christ's Team...
I was going to put a B18A1 into my EG hatch. But the B18A1 is a cable tranny, and the EG ran a hydro tranny if i'm not mistaken. What's the cost of a hyrdo-cable tranny conversion kit? And does it bolt right in?
Old Apr 28, 2003 | 07:37 AM
  #86
Kai's Avatar
Kai
Rotorphile.
HASport makes the conversion kit you need, it is bolt on and costs around $200. For that price you might want to look into selling the cable transaxle and buying a hydrolic one.
Old May 10, 2003 | 08:53 AM
  #87
ISP James's Avatar
ISP James
DAMIMRED
d16y8 into a crx dx... i know it needs the dpfi conversion harness but if i get the engine bay harness from a 96+ d16y8 it should be relatively easy, right? i dont have to worry about wiring interference to the rest of the car?
Old May 10, 2003 | 11:01 AM
  #88
jaje's Avatar
jaje
HC Racer H5
i'm not sure if the engine harness from a 96+ will just snap onto the car's main wiring harness...i don't think it will be as simple as it sounds...i'd research the hasport's dpfi - mpfi engine wiring harness conversion package (you will need the injector solenoid and several other bits)
Old May 26, 2003 | 03:00 PM
  #89
mang's Avatar
mang
b16a1 into an 89 hatch
if i get this kit what else to i need to modify to get the swap done?
Old May 27, 2003 | 09:48 AM
  #90
4thgen91EFhatch's Avatar
4thgen91EFhatch
i will soon be buying a zc longblock from hmotorsonline.com...but here's my problem...i have a 91 dx automatic hatch...it has to go to manual...should i get an si tranny and put it on my d15b2 now and also switch to MPFI with the 88-89 teg DOHC ecu?...or should i wait til i get the zc to swap it to manual and MPFI?...thanks
also...what are the stock hp and tq ratings of a DOHC ZC?
