Post Questions about engine swaps.
Old Jun 20, 2003 | 11:36 PM
  #101
Kai's Avatar
Kai
Rotorphile.
Originally posted by awhell
will there be any other major mods to watch for like cutting or anything else ??
You may need to dent the frame rail to make room for the alternator pully. A few good wacks with the good ole' BFH should fix this problem. Using a shorter alt. belt may save you from banging on the chassis.
(page 3 ownerages!)
Old Jun 26, 2003 | 11:45 AM
  #102
Mr. UnderHill's Avatar
Mr. UnderHill
Love Is Suicide
Default GSR in a 89 Civic (4 door)
I'm planning on swapping a GSR into a 89 Civic (4 door) I have all the money saved up. I was just wondering if I could get some insight as to which year Integra I should take it out of. And what other things I'm going to need(Wire harness, Motor mount..etc) And if it's worth it in general. Any input would really help.
Old Jul 10, 2003 | 08:31 AM
  #103
Knightmare69's Avatar
Knightmare69
Hater
Default D16Y8 into 91 Dx
What is needed to swap in a y8 into my GF's 91 Dx? It's suposed to be bolt in correct? But obviously there are other issues besides that that need to be addressed. Also, did the Y8 ever come in a auto tranny configuration as that's what my GF's civic is and she does not want to learn stick. If not, what are my options for bolt in swaps for the auto tranny? I'm not looking for super power but anything is better than the 1.5 she's got in there now. Thanks in advance.
Old Aug 18, 2003 | 06:56 PM
  #104
Jlockheed's Avatar
Jlockheed
Which axel combo do you need for a b18 swap? Anybody got any links to a b18c install? Im trying to set up a gsr swap, and trying to stay as simple as possible. I was thinking of using a b18c (perhaps a c5) block and then using everything else from a 1st gen b16 swap. Im pretty sure the ecu would have to be chipped, for the bigger engine but aside form that im not too sure what else would be need.
Thanks in advance,
Old Aug 19, 2003 | 05:51 AM
  #105
jaje's Avatar
jaje
HC Racer H5
Thanks in advance,
usually you'd want to use a set of axles from a 90-93 teg for a b series swap into an ef chassis
Old Aug 24, 2003 | 12:18 AM
  #106
hondatech's Avatar
hondatech
Honda tech/eprom hackr
Okay, I got an idea, Only true Honda guys will know/understand this one. Will a s2000 f20 fit into a s600? Ah now that would be a sweet swap. If I had the money I would do it.
Old Sep 2, 2003 | 03:45 PM
  #107
Kai's Avatar
Kai
Rotorphile.
No. The engine bay was made to fit a V-twin two cylinder, and it used a chain drive system for the rear axle, no driveshaft. The bay would be way to small, plus it would be hell to adapt it to the S2000 drive system.
I had the oppertunity to get two Z600's for free, but I had nowhere to put them. Not quite an S600, not even close, but they were made around the same time. The S600 was never officially imported into the United States, and they are rare as hell in Japan.
Old Sep 2, 2003 | 08:31 PM
  #108
hondatech's Avatar
hondatech
it's only money, The s800 had a driveline. You could shorten the s2000 diff. and driveline to make it fit. I bet you could shoehorn and do some welding and get the engine it. I waqs thinking the problem would be the middle tunnel. On the s2000 it's really high, but the s600 it's not even there.
Old Sep 2, 2003 | 08:41 PM
  #109
Kai's Avatar
Kai
Rotorphile.
I would imagine the rear axles of the S2000 would be way too wide for the S600, not to mention the differential itself would probably be way too big to stuff under the car.
It's a neat idea, but those cars are tiny little roadsters. It would take a lot of work and serious modification to a rare and valuable car. Not worth it IMHO.
Old Sep 2, 2003 | 08:49 PM
  #110
hondatech's Avatar
hondatech
i know huh, the parts for them are hella hard to find. My friend has a 65 in storage I'm considering buying from him.
