A/C Belt increase HP???
you would free up some power yes, but it would be nowhere near 20 Hp. I would guess more around 2-5 or so. But I wouldn't worry about it. Some cars disengage the A/C drive pulley at WOT, so this isn't even an issue, because the only time you are going to be using that last 2-5 hp is at WOT.
I am not sure if Honda is the same way though. Someone else can fill in that bit of info.
heheh yeah
on accords and ludes the ps pump, alternator and compressor are all stacked...and the ps pump has its own belt while the alternator and a/c share one.
kind of a hassle to service the a/c compressor...more than ahassle actually, more like a pain in the ass.
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
On most 4-cylinder engines, you will loose somewhat noticeable power with the A/C on, since there is a lack of torque. With most V-6 and V-8's you won't notice anything. But if you need the power, just don't run the A/C at the time. Cutting the belt won't do much for you.
