You're running a straight pipe? This could be related to why you are runing rich/lean. Your ECU could be reading too much on emmissions and leaning your fuel mixture out to try and correct it.
I don't think it's because of the straight pipe because I had the code even before the straight pipe. can i fix it by buying the VAFC? Also, how much and what does it bascially do?
It might be a possability, but you need to find out why you are too rich/lean first cause it may be just a simple thing you need to do instead of haveing to go buy a $300-$400 piece of electronics.
