Check Engine Light 45
Maybe it is because you are using the wrong ecu? :doh: Your car has no secondaries, which means you run really lean before 6000 rpms, and hella rich after.
Not to mention the fact that you have less displacement and less cam duration...
If you are in Cali, go to this post, this guy has an OBDII ECU for sale.
http://forums.civicland.com/viewtopic.php?t=5635
99-00 Civic ECUs are not OBDII
