9k redline with turbo
Old Aug 10, 2002 | 03:11 PM
szm426's Avatar
szm426
Default 9k redline with turbo
hey guys i was thinkin, how much would it cost to build up a motor with a 9k redline and also have it withstand like 20+ lbs of boost, if this is even possible.
Old Aug 10, 2002 | 04:36 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Its easy... but you have to approach the problem one step at a time..keeping the other in mind. I would suggest building for boost first.Get a computer, swap out the injectors, rods and pistons and get the whole rotating assembly balanced down to a gnats ass. Run some boost. Then work on your valvetrain, then upgrade your ignition. THEN raise your redline
Old Aug 10, 2002 | 07:24 PM
dubcac's Avatar
dubcac
I
If you wanna boost 20+, it's time to resleeve that block.
Old Aug 12, 2002 | 12:34 AM
evo119's Avatar
evo119
GO GIANTS!
Anything is possible...with that much boost you're going to definately bulletproof the block....resleeve, forged rods/pistons, balance the crank...etc. I hope you're not planning to make this a street car.
Old Aug 16, 2002 | 10:11 PM
pimpdaddypat's Avatar
pimpdaddypat
yea thank god you last two recommend resleeveing the block i was reading theroosters posting and i was like ohh boy someone forgot one of the most important parts
like evo119 said time to "bulletproof the block"
i don't know why you need 20 pounds though
Old Aug 18, 2002 | 06:42 AM
jdblack1's Avatar
jdblack1
you're looking at 8k at least.
you have to think about all the little parts you need that will cost.
fuel pump, lines, filter, fpr, injectors, fuel rail
clutch, axles, Differentials because you'll probably break stock
mounts, pistons, sleeves, rods, bearings
turbo components, turbo, oil lines, water lines, intercooler piping, wastegate, BOV and intercooler.
ignition parts
ECU, boost controller
and then if you get all that you can't run it at the strip because it's too fast so you have to get a rollcage and some slicks
Same thing goes for the autocross, which I don't think you plan to do much of with 20+ psi of boost.
Old Aug 18, 2002 | 06:44 AM
jdblack1's Avatar
jdblack1
also why 9k redline. You don't need all that.
a properly sized turbo good to 9k at 20psi of boost is gonna cost you a new one a$$hole
I like the new GT30's but they are about 1500
Old Aug 18, 2002 | 09:32 AM
dubcac's Avatar
dubcac
I
Yeah, but 20 lbs @ 9k would be so BADASS!!
Old Aug 18, 2002 | 02:54 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Eh... it's all in what you wanna do, I still plan on building a turbo CRVTEC in the next few years, and feel confident that I can build a daily driver that will boost 9psi street and 22 at the strip. With 2.0L and a good throttle foot, I'd even autocross it. Of course, to do all that I'm set to spend about $15k just on the engine, so like I said, it's all in what you wanna do.
-Harry
AIM: NDcissive
Old Aug 18, 2002 | 08:06 PM
JUN_B18C5R's Avatar
JUN_B18C5R
ya, it will run about $15K, trust me, I've done it. I wrote out a list on here just a min. ago, but the website froze and I lost it all. So if you need a list, let me know. Lata.....
Crf450r420
Prelude
4
May 22, 2009 05:03 PM
93_Accord_SE
Accord
13
Sep 9, 2007 04:30 PM
Nelson
92+ Civic/EL & Del Sol
4
Jul 23, 2002 11:40 AM
drdavidge
Jul 22, 2002 07:16 AM
swtchink13oi4u
12
Jul 1, 2002 08:26 PM
