Where to check oil on manual gearbox?
Old Jul 4, 2002 | 10:17 AM
bmwguy's Avatar
bmwguy
Default Where to check oil on manual gearbox?
I have a '92 Civic VX with a 5spd and I'd like to check the gearbox oil level. I looked around and the only plug I could find is on the very end of the case on the passenger side. Is this the place to check the level? Also, what should I use for oil? I just picked up the car and it doesn't have an owners manual.
TIA
Dan
Old Jul 4, 2002 | 07:00 PM
jdblack1's Avatar
jdblack1
there should be one plug that's almost at the bottom of the tranny that has just a 3/8's square in it. That's the drain plug.
The fill plug is to the left of it about 2/3rds up the tranny. It has a 17mm or so hex and a large flat mating surface.
Just use 10w-30 motor oil in you're tranny. Use a good brand, but I wouldn't suggest something super slick.
Old Jul 4, 2002 | 07:34 PM
qtiger's Avatar
qtiger
:down: :down: :down:
Wrong additive package.
Old Jul 5, 2002 | 06:03 AM
AzDrag's Avatar
AzDrag
No you need to runa thicker oil than that. Just got to the parts store and they will have a small section that has manual tranny oil. Manual trannies take much much thicker oil.
Old Jul 5, 2002 | 06:41 AM
jdblack1's Avatar
jdblack1
Uh what. Honda manual trannies use 10w-30. If you don't use Honda MTF then put in the 10w-30.
Old Jul 5, 2002 | 06:58 AM
AzDrag's Avatar
AzDrag
Ahhhh your right. I was thinking about my buddies Acura we just did. The honda does take 10-30.
Old Jul 7, 2002 | 06:59 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
FWD trannies take Honda MTF or comparable or 10w-30. Rear wheel drive trannies can take 90w gear oil depending on manufacturer design, and rear wheel drive diff cases take 90w. Putting 90w in a FWD tranny normally leaves you about one shift before the oil expands with emulsified air and prevents the linkages from moving correctly.
-Harry
AIM: NDcissive
Old Jul 7, 2002 | 09:06 AM
jdblack1's Avatar
jdblack1
welcome back:thumbup:
Old Jul 7, 2002 | 11:32 AM
1stGenCRXer
Good to be back, now I just need to catch up on all these topics
Old Jul 7, 2002 | 12:22 PM
jdblack1's Avatar
jdblack1
really has been that much
sputnik
CRX & Pre 92 Civic
3
Nov 8, 2006 11:27 AM
MrFatbooty
News & Rumors Archives
5
May 9, 2005 07:41 PM
puffy
Nov 5, 2003 01:05 PM
