JDM ITR 5 Lug Conversion on 99 Civic SI - HELP
Old Jul 10, 2002 | 07:56 AM
DarkKnightWong's Avatar
DarkKnightWong
Default JDM ITR 5 Lug Conversion on 99 Civic SI - HELP
Hey everyone,
I about to get a JDM ITR 5 lug conversion for my 99 Civic SI.
I been told I will run into problems with my SI axles?
I was told that the JDM ITR 5 lug use a 36mm axle, while the USDM ITR and any other B series car uses a 32mm axle?
Can anyone shed some light on this??
I dont want to tear down my car and find out that I'm going to need more parts to get the 5 lug workin on my SI.
Has anyone used a JDM ITR 5 lug conversion before with stock USDM B Series axles?
And if they are different, does anyone know where I can get JDM axles? or should I just go buy the USDM Hubs from acura? I guess all I would have to change would be the front hubs and maybe the bearrings??
Thanks in Advance for the help.
DK
Old Jul 10, 2002 | 08:19 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
i'd have to disagree.
i think the jdm itr has the same 32 mm axle nut like the rest of us.
Project EVA - The Track Package
Project EVA
Old Jul 10, 2002 | 08:35 AM
DarkKnightWong
If it is ..
That would be sweet
I was told by a few people it is 36mm
I guess I will have to wait and see...
Old Jul 10, 2002 | 04:45 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
Maybe the axle nut for some odd is requires a 36 mm socket, but i don't see why it would be a 36 mm axle
hell look at all the jdm itr swap in usdm civic's.
no jdm itr hub's needed...
Project EVA
Old Jul 10, 2002 | 11:45 PM
dnt94civic's Avatar
dnt94civic
Well, if you are getting the 5 lug conversion off a jdm integ type R, then you will need the axles from the jdm teg. only the usdm tegs 5 lug will fit with your current si axles. one of my friends who did the conversion ran into this problem.
Just to let you know
Old Jul 17, 2002 | 10:36 AM
DarkKnightWong
I dont have the JDM Axles.
I think the guy sold them with the SWAP.
Is there any place I can get a set of JDM ITR Axles????
Is it possible to just swap out the HUB, that part the axles goes into with a USDM piece.???
Thanks
DK
Old Jun 6, 2004 | 07:09 PM
MaliceCrew's Avatar
MaliceCrew
Default JDM Axles
I Just ran into this Problem now! upon doing some research I discovered that this: USDM 5-lug = 32mm, JDM 5-lug = 36mm, So now I need to go out and find JDM ITR Axles and I have no Idea where to find them please help me out guys! I can't drive my car until I find and Install these!
Old Jun 7, 2004 | 02:22 AM
NAR-SPEC.com's Avatar
NAR-SPEC.com
I have a set. 300 + shipping obo.
36mm alxes with nuts and all.
Very rare item.
Old Feb 25, 2005 | 09:15 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
what is a parts list for everything needed for this swap?
Old Mar 8, 2005 | 07:17 PM
93jdmgsrhatch's Avatar
93jdmgsrhatch
for $300 u can probably go to acura and buy hubs and not have to owrry when u break an axle that u have to spend $300 and wait a month for axles
