Timing Belt Broke
Old May 31, 2004 | 03:23 PM
Zedron's Avatar
Zedron
Turbo B20
Default Timing Belt Broke
My timing belt just broke, what is the probability that i bent valves?
Old May 31, 2004 | 05:51 PM
Zedron's Avatar
Zedron
Turbo B20
ttt...
Old May 31, 2004 | 06:02 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
How fast were you going? Any sounds when it happened? You can try to replace the belt and hope for the best...
Old Jun 1, 2004 | 03:36 PM
Zedron's Avatar
Zedron
Turbo B20
I was only going 40 at 3k rpm and no sounds, just stalled out.
Old Jun 1, 2004 | 03:44 PM
Kai's Avatar
Kai
Rotorphile.
Replace the belt. It will either run fine, run lke hell, or not run at all.
If it runs fine, you're lucky.
If it barely runs or doesn't run at all, you need to crack open the engine and see what happened. You may have bent or broken valves, scarred pistons or even cylinders. At 3k RPM, the damage is probably minimal if any.
What engine do you have? Some have much tighter tollerences then others.
petrv
Prelude
10
Mar 17, 2004 07:50 PM
petrv
Engine Swaps, Tech & Tuning
Mar 1, 2004 03:30 PM
JiggaFan
4
Feb 22, 2003 01:38 AM
