Timing belt vibrations (video)
Old Feb 29, 2004 | 11:36 PM
petrv's Avatar
petrv
Default Timing belt vibrations (video)
I probably figured out my problem with noise going form timing belt area after the timing belt change. I was not alone with this problem, more people have these problems.
I knew (and many people told this to me) that when I loose my timing belt, the noise stops, but I was worried about vibrations that the belt made when the engine was running. Today, I made some videos with my and my friend's lude to ask you about it.
Here are the vids:
Original state, with the tensioner set according to the Helms, the noise is still present:
engine running - no vibrations
belt slack with piston #1 at TDC - looks pretty tight
Loosened belt, so the noise has gone:
engine running - the noise has gone, but notice the vibrations at some engine speed. Is this ok?
belt slack with piston #1 at TDC - looks unchanged
maximum belt slack - I tried to rotate the crank and find the position with maximum slack - here it is. Looks loose.
I was really confused, so I called my friend with the same lude (H22 4G), but still with the auto tensioner, so the results should be the right ones.
engine running - the vibrations look exactly the same as mine
belt slack with piston #1 at TDC - looks same as mine.
maximum belt slack - again same as mine.
So, I hope the vibrations are OK, what do you think? Can I drive with this belt slack and vibrations? Or is this slack not normal?
Old Mar 1, 2004 | 03:30 PM
sensei's Avatar
sensei
I would try to find a middle ground between the two. The belt noise is a bit much, but the slack doesn't look good either. I've never noticed that much slack in any of my cars. The noise will probably subside after a week or so. If you followed the procedure and it makes a little noise, you might want to drive it for a few days to see if the noise subsides.
petrv
Prelude
8
Jun 22, 2003 07:54 AM
ChrisGSR
Engine Swaps, Tech & Tuning
2
Mar 24, 2003 03:43 PM
ChrisGSR
20
Feb 26, 2003 09:07 PM
JiggaFan
4
Feb 22, 2003 08:55 PM
JiggaFan
4
Feb 22, 2003 01:38 AM
