B16 or B16A2
Old May 16, 2004 | 07:10 PM
TotalVelocity's Avatar
TotalVelocity
Default B16 or B16A2
I want to build up a B16A engine should i go with the B16 A2 blocjk or the B16 block...i was thinking the B16A2 b/c od the obd2 vs the obd 1 right??
Old May 16, 2004 | 11:43 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
In terms of mechanical "quality" (if you want to call it that) they are essentially the same.
What year car is this going into and what sort of ECU is going to be running it?
Old May 17, 2004 | 08:57 AM
TotalVelocity
and also would it be smarter t ogo with a D16z 6b/c of the HP and torque....... ihave a 92 civic DX 4 door
Old May 17, 2004 | 10:06 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
if you have a 92 civic, it will be easiest to use an OBD1 motor.. either a B16a2 or a JDM b16a 92-95....
If you want a cheapy motor, the d16z6 is a pretty good deal and a nice motor, but it has lower power potential than the B-series.
Old May 18, 2004 | 08:37 AM
TotalVelocity
one of my friends was telling me to go with the d series because i coul get more power for cheaper amount of money
Old May 18, 2004 | 11:47 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Well then your friend doesn't know what they're talking about. The B-series has far more power potential.
Since this is a '92 car the simplest thing for you to do would be to get your hands on a JDM B16A swap from a '92-'95 Civic SiR or SiR-II and go from there.
What exactly do you mean by "build up"? Are you actually going to disassemble it and replace all of the internals?
Old May 18, 2004 | 05:13 PM
white_n_slow
it's my D in a B
if you go with the d16z6, pretty much the only way you'll make significant power is with a turbo or nitrous. The ceiling, in terms of power, will be in the 160-220 range unless you rebuild the motor to accept more punishment. The D-series option has a lower initial cost, but you can only go so far before you run out of ways to improve power.
A B16A or B18B cost a little more, but have a much higher power potential. Keep in mind, a well-tuned, turbo'd D16z6 will make loads more power than a stock (or moderately modified) B-series... but turbo/nitrous that B-series motor, and you'll blow the D out of the water. Either route has its advantages. What, exactly, is your power/performance goal? Figure that out first, and it will be easier to tell where to go.
Old May 20, 2004 | 11:25 AM
TotalVelocity
im going to completely replace the internals and sleeve it...and turbo it...i was thinking the B16A would be better also
Old May 20, 2004 | 11:27 AM
white_n_slow
it's my D in a B
wow, if you're spending all that money and turboing anyway, you might as well go with something other than a B16... I'd suggest a B18B or B18C.
Old May 20, 2004 | 11:29 AM
TotalVelocity
yeh but i dont think it will fit in my 92 4 door civic DX
