Engine maintenance light stays on?????
My son is walking around with the PVC valve out of his 95 Integra asking me if rattles is it good. His engine maintenance light has come on and he cannot get it to reset. I asked him to stop at some of the garages in town and have them read the error codes. He says it is not the check engine light and the couple places he has tried do not have the correct adapter. Being brought up on small block Chevys with distributors and Rochester carbuetors I’m not sure if there is a simple fix. Does anybody have some advise?
Thanks, Ben
Thanks, Ben
The "maintenance required" light is set to come on something like every 7500 miles. It's basically just an oil change reminder. There's a button under the dash that you can use to reset it.
These threads should give you all the info you need:
https://www.honda-acura.net/forums/s...d.php?t=106566
https://www.honda-acura.net/forums/s...ad.php?t=61020
https://www.honda-acura.net/forums/s...ad.php?t=78784
Ramman949
49
Apr 27, 2004 07:51 PM
