Can I get an answer besides...
Old Jun 24, 2003 | 07:07 PM
UrbanFuturistic's Avatar
UrbanFuturistic
Default Can I get an answer besides...
...hit the reset button?
This afternoon/evening I got into my '94 LS to go for a short ride. When I started the car, I noticed the Maintenance Required light is on constant now. I have no clue why. I just had the oil changed, along with the spark plugs. Other than taking a while to "warm-up" in the morning, there is really nothing wrong with the car. Any ideas are greatly appreciated.
Old Jun 24, 2003 | 07:14 PM
LT's Avatar
LT
The deer had to die!
All i cna say is reset the light? Its lit according to mileage, not sensors or ECU codes.
Old Jun 24, 2003 | 07:15 PM
UrbanFuturistic
If thats the case, why does just over 93k seem a bit odd to me to just "pop-on"?
Old Jun 24, 2003 | 07:25 PM
Amirked's Avatar
Amirked
read the manual - if its the same as my 95 ls that light will come on and blink for the first 10 seconds after you start it if it has not been reset in the 3,500 miles - if you do not reset it before 7,500 miles it will come on and stay on - so therefore if that is the case just reset it . . most shops dont reset them so i bet thats your problem - the manual will tell you where to find it to .. i know its not the answer you want but it makes sense to me
Old Jun 24, 2003 | 08:14 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
I believe that the light will come on 7500 miles from the last time it is reset. When you did your oil change they must not have reset the timer. It's not the answer you want but just reset the light yourself and you will be good to go. Having your CEL light...that's a different story!
Old Jun 24, 2003 | 08:29 PM
dubcac's Avatar
dubcac
I
Break the light.
There's a different answer
Old Jun 24, 2003 | 08:55 PM
qtiger's Avatar
qtiger
If you don't want to reset it, I would recommend deep fat frying your testicles at 350 degrees for about 10 minutes or until golden.
Old Jun 24, 2003 | 09:15 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
...ouch
Old Jun 24, 2003 | 09:33 PM
airon's Avatar
airon
AARONNOJIMA.COM
its a warning feature
if comes on after so many miles
i think its every 5000 miles it starts flashing and 7500 constant
so say someone reset it at around 85,000 miles it would come on around 93k
Old Jun 25, 2003 | 05:03 AM
teg_fan's Avatar
teg_fan
I like integra's
lol:barf:
