removing AC condensor fan
Old Jun 30, 2004 | 06:09 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
Default removing AC condensor fan
Hey all,
the use of my new turbo manifold will require removal of the normal AC condensor fan. For the moment, i might just run without the fan, I know my AC would suffer, but its better than removing it. I plan on adding a Pusher fan as soon as i can, but its another headache i dont need right now.
Anyway, Is this safe to do? Is the only consequence that my AC wont be as cold? Or could i potentially damage components?
Old Jun 30, 2004 | 05:28 PM
cartuner's Avatar
cartuner
You'll be ok without it until you get a pusher fan. just don't use your a/c while you're idling waiting around. Once you're moving the condensor fan is rarely used.
Old Jun 30, 2004 | 07:16 PM
s1ngle's Avatar
s1ngle
what will happen if i ran it without a fan while sitting still? just out of curiousity... not planning on doing it
Old Jul 1, 2004 | 04:20 AM
ED9man's Avatar
ED9man
driver
I have 2 fans on my car, is one only for the condensor?
Old Jul 1, 2004 | 07:30 AM
s1ngle's Avatar
s1ngle
hahah, yes one is for the radiator!
Old Jul 1, 2004 | 09:10 AM
Toyz51's Avatar
Toyz51
It won't transfer heat as well, but as far as damaging things, you should be ok. If worst comes to worst, the pressure in your system will kick a pressure switch, then shutting off the compressor clutch until pressure goes back down.
Old Jul 1, 2004 | 10:29 AM
ED9man's Avatar
ED9man
driver
Since I ripped out my compressor will the other one not come on anymore?
