Piston removal
Old Jun 4, 2004 | 07:24 AM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
Default Piston removal
I'm going to send my b18c1 head out to get rebuilt (guides, seals) and while it was out, I was planning on changing my rings. I don't want to remove the block from the engine bay, so I'll do it from under the car. How difficult is it to knock the piston out, if the crank is still installed? I wouldn't want to damage the oil jets.
Also, when re-installing the rods, they don't specify this in the Helms manual, but I'm assuming oil must be applied to the rod bearings before reassembly?
Old Jun 4, 2004 | 09:36 AM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
Nevermind, I just realized that it would be simpler just to take the engine out or to get it done, cuz I would need to hone the cylinders.
Old Jun 6, 2004 | 03:51 PM
civicon19s's Avatar
civicon19s
and if your going to do all that, you might as well just do it right and rebuild/replace everything or just get a new motor..
Old Jun 7, 2004 | 02:15 AM
NAR-SPEC.com's Avatar
NAR-SPEC.com
I would just get new pistons and rings (p73, p30's) or if you have the money.. get a forged pistons.
You'll get a slight bump in compression and a fresh motor too.
Old Jun 7, 2004 | 10:56 AM
B20powered's Avatar
B20powered
You can't see me
Swapping rings isnt all that hard in the car. drop the oil pan and girdle. un bolt eht rods from the crank. unbolt the crank and drop it out. un bolt the oil sprayers. Get a friend for this. One person go under the car and the other take the wooden end of the hammer and push the piston out the bottom. have the person under the car try to not let it hit the ground. when you got your new rings on bolt in the sprayers and bolt in the crank. now make sure you put rubber caps on the end of the piston bolts so they dont scratch the crank. you will need a piston ring compressor to get them in. Make sure to torque eerytihng properly.
Old Jun 8, 2004 | 09:39 AM
civicon19s's Avatar
civicon19s
doing that sounds like a mother ****er!
Old Jun 10, 2004 | 07:11 AM
DarkLightning's Avatar
DarkLightning
Hey, at least you can do it from down below.
Old Jun 10, 2004 | 09:42 AM
Eddiebx's Avatar
Eddiebx
which motor are you talking about that you can push the pistons out the bottom? cuz on the f and h motors i've worked on theres this lip so u can get it out the bottom, must go from up top. are the b-series different? i've never sat down and taken one of those apart before, hehe
CapYoda
92+ Civic/EL & Del Sol
15
Nov 12, 2006 09:57 PM
split
Jul 3, 2003 03:24 PM
se93
Dec 29, 2002 04:00 AM
Trambitis
Engine Swaps, Tech & Tuning
2
Nov 14, 2002 12:55 PM
Trambitis
Nov 14, 2002 12:04 PM
