bored .02 over, piston ring combo?
Old Apr 26, 2004 | 05:07 PM
javenger's Avatar
javenger
Default bored .02 over, piston ring combo?
i have a ls block that is bored .02 over. what size pistons and rings should i use. i plan on boosting the motor i build (only 7-10 psi). stock size pistons, with larger rings? or should i get .02 over sized pistons? help, noob at building motors.
i also i have a stock ls block. what should i do....
Old Apr 26, 2004 | 05:15 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
over sized pistons if you go stock might lose compression
Old Apr 27, 2004 | 05:32 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I had some .02 overbored pistons/rods at 9.5:1 for sale not too long ago. You need to get the oversized pistons for that bore size. Too much of the rings will be exposed if you just run standard sized pistons.
Old Apr 27, 2004 | 11:09 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You should be able to get the proper oversized pistons and rings at any Acura dealer's parts counter.
eghonda
Engine Swaps, Tech & Tuning
Nov 25, 2003 07:51 PM
