d16a1
Old May 5, 2004 | 12:46 PM
integra93jdm's Avatar
integra93jdm
Default d16a1
my friend has a 89 integra with a d16a1 and wants to put pistons on his car the only pistons are for a d16a6 will the pistons work if they got the same bore and should he stay with the oem head gasket or go with a 1 or 2 layer gasket
Old May 6, 2004 | 10:55 AM
Kai's Avatar
Kai
Rotorphile.
D16A6 sized pistons should work fine, they have the same basic block config. The wrist pins should also be the same size, IIRC.
If he wants higher compression, throw in some ZC pistons. Cheap, and they work.
Old May 7, 2004 | 03:32 AM
AwwsChwA's Avatar
AwwsChwA
Dude...punctuation is a beautiful thing.
Are you putting A6 pistons into an A1? Or the other way around?
Putting A1 pistons into an A6 will yield roughly 11.5:1 compression.
Putting A6 pistons into an A1 will yield really low compression. You'll be running less than 8:1. Even for a turbo, that's too low.
A6 and A1 pistons use the same rods and wrist pins. Not sure about the rings.
s4yama
Engine Swaps, Tech & Tuning
3
Mar 4, 2004 12:26 PM
vTeggy86
4
Jan 16, 2004 08:33 AM
lime91crx
CRX & Pre 92 Civic
19
Jan 7, 2004 05:23 PM
Meeky
3
Jun 27, 2003 06:02 AM
chauncey_333
Jun 25, 2003 07:59 PM
