Gs-r Crank In Ls Block With Itr Pistons
Old Dec 29, 2002 | 12:28 PM
RedUSDM'97TypeR's Avatar
RedUSDM'97TypeR
Default Gs-r Crank In Ls Block With Itr Pistons
WILL THIS WORK?
Old Dec 29, 2002 | 01:14 PM
qtiger's Avatar
qtiger
Yes, if you turn off your caps lock.
In all seriousness, it will work, but you'll want to use GSR or ITR rods. I would strongly advise considering a crank girdle if you'll be revving it very far.
Old Dec 30, 2002 | 04:55 PM
SiR-DC2's Avatar
SiR-DC2
Better off running an LS crank in a GSR block...but only if your caps are off.
Old Dec 30, 2002 | 05:21 PM
dubcac's Avatar
dubcac
I
Why put a GSR crank in an LS block? You are destroking the motor, so you'll lose displacement and torque.
Old Dec 30, 2002 | 05:55 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
It's marginally safer at high revs. I wouldn't bother though just because of the cost associated with a new crank. If you want the LS bottom end to be rev-safe, then get some forged rods and a crank girdle.
