In Need of Help With Primary O2 Sensor Wiring
Old Jan 4, 2003 | 11:44 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
Default In Need of Help With Primary O2 Sensor Wiring
hey guys i need your help, my stock O2 sensor was eaten up which looks like a rat or something so i went to the local boneyard and found the 4 wire O2 sensor i need only problem was the engine had front end damage and i had no choice and limited tools on hand so i cut the wires. so now im at home and i cant figure out which heater wire is which. i looked in my helms and it only shows which is which if your looking at the plug not the O2 sensor itself and my stock one was cut also cause i tried to repair it but that was immpossible.
all i need to know is when you look at the wires coming out of the O2 sensor in this sequence black-green-black-white i just need to know which black is positive and which is negative for the heating element inside on the O2 sensor itself.
thanks
Old Jan 4, 2003 | 04:24 PM
Brian's Avatar
Brian
on the sensor clockwise
white, black1, green, black2
on the connector top left (by the part you press)
black2, black1, green, white
Old Jan 4, 2003 | 08:39 PM
NeverBX's Avatar
NeverBX
thanks for your help, i found a web page that shows an illustration about it. if you guys wanna check it out it also shows how to convert 2 wire to 4 wire O2
http://ludicrous2_0.tripod.com/how_to/oxy/
