cam gear questions
Old Dec 21, 2002 | 11:27 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default cam gear questions
as u all know, i posted up a thread in here a while ago about Jun cam gear for the sohc y8. here is my question... can i still use my stock cam shaft or do you know if JUN makes one for the y8 as well? an how hard is it to install it? i have the manuals... but do i need to mess with the valves???
Old Dec 22, 2002 | 09:35 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I don't think JUN makes a D series cam. As for installing a cam in a SOHC, you would have to remove the lost mostion and rocker arm assemblies to get to the camshaft. Yes, you would need to set your valve lash afterwards.
Old Dec 22, 2002 | 10:14 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
:doh: so i guess it's better to have a professional to install it? cuz i've read other people's posting on the valve adjustment... and it's quiet confusing.... since mostly are dealt with the FEEL process. do you have any site perchance that will be more informative in details???
Old Dec 22, 2002 | 11:48 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
http://www.c-speedracing.com/howto/v...alveadjust.php
That's for a B18C, but it's the same process for a Y8, except you don't need to make/buy a tappet adjuster tool. All you need is a 10mm box-end wrench, a flatehead screwdriver, and feeler gauges.
