running rich on my d16z6
what could be the problem?
I took out my new plugs and saw it was running rich (sooty black) also my lil civic is drinkin gas (22mpg).... I dunno whats wrong. I recently replaced the cap, rotor, ignition coil and plugs. No CELs, tire pressure fine, no dragging brakes.... what could be the problem? to my knowledge the A/F mixture is controlled by the ECU...... what sensors controll it too?
help!
*update* it seems to get good gas mileage this tank... but that means it a speratic problem and I want to fix it before it starts to suck gas again...
help!
Yeah, the Red Line stuff is money.
Let your tank run down, dump the bottle in, then fill er up. After the whole tank is run through the fuel system should be much cleaner. It's possible that the filter wtill still need to be replaced even after the cleaner.
h:
