Need brake help ASAP.
Old Dec 20, 2002 | 07:42 AM
sleepin's Avatar
sleepin
Default Need brake help ASAP.
I am doing a hybrid front brake setup and I need to make shims to get the caliper to fit properly, what I need to know is how far does the outer caliper frame(houses outer pad) need to be from the rotor? This will help me in knowing how thick the shim will need to be. Thanks. Below are the parts being used if that will help-
92 civic knuckle
94 GSR calipers
AEM big brake kit(stock caliper relocation kit)
