roughly, cost for B series rebuild?
This spring I would like to have my b18b rebuilt. I would provide some aftermarket parts but what is an estimated cost for a rebuild with stock internals?
And if anyone has any internal aftermarket parts suggestions for this motor running n2o set-up let me know.
Bearings - $200
Rings - $100
Water Pump - $75
Timing Belt - $50
Rod Bolts - $100
Main bolts - $150
Headbolts - $150
Gaskets + Seals - $300
Valve Guides - $100
Cap + rotor - $50
MMW (Miscellanious Machine Work) - $300
add forged pistons - $400
add forged rods - $400
add headwork - $500
add getting someone else to put it together - $300
its not cheap! I'm rebuilding a B18A block right now for LsVtec, and it's costing me way more than I thought. I probably even forgot some stuff. You might as well get a GsR, at least it'd be fast too then, or try and find one that is already rebuilt, they seem to sell for cheaper than it costs to rebuild one.
Rings - $100
Water Pump - $75
Timing Belt - $50
Rod Bolts - $100
Main bolts - $150
Headbolts - $150
Valve Guides - $100
Cap + rotor - $50
add headwork - $500
Labor in your area is probably similar but the last few that I built for customers averaged about $600 labor plus parts.
Bore and hone - 50
clean and prep - 50
press rods on/off pistons - 16
valve job and surface - 130
assemble - 350
BTW oem pistons/rings are about $325-350 a set
I would use forged pistons with N2O. If you add ARP bolts prepare to have the rods resized as well as the extra clamping force distorts the bore - add $15/rod plus parts. The stock rods with these bolts will handle plenty of spray as well as the crank.
I tend to avoid copper head gaskets in 99% of all applications as they leak and you need to make sure the coolant holes are set up right to avoid overheating. Stick with factory Honda/Acura parts as much as possible.
Bore and hone - 50
clean and prep - 50
assemble - 350
