91 civic dx won't start
Old Dec 24, 2002 | 06:35 AM
highwayman32's Avatar
highwayman32
Default 91 civic dx won't start
my wife's 91 civic is dead (won't start). she's tried to get a
boost but all she hears when she turns the key is a click. any suggestions? a quick response would be appreciated as she's stuck where she works on xmas eve. is there any way to
get this running enough to get it home. its an auto. thanks
Old Dec 24, 2002 | 07:22 AM
highwayman32
got the story straight. it turns over but won't start. i won't know if its a fuel or electrical problem until i get home. any suggestions as to common problems for this year/make of civic? thanks.
Old Dec 24, 2002 | 01:12 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The ignitor inside the distributor tends to go bad which will prevent starting.
Old Dec 25, 2002 | 09:32 AM
z24hedturnr's Avatar
z24hedturnr
U want that Woo WOO
Yeah... pull one of the spark plugs and ground it and try to turn it over to see if you are getting any spark, with the results take it from there but that is most likely what the problem is.
Old Dec 26, 2002 | 12:08 AM
highwayman32
Default nope
spark is fine, i can't hear the fuel pump when the switch is in the "on" position. main relay was replaced in july. i'm getting 12 volts back at the connector under the seat but at the connector under that little panel, i'm only getting 6.4 vdc. any suggestions? fuel pump bad???
