better throttle response?
Old Dec 14, 2002 | 01:34 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default better throttle response?
what did he mean by pulling on the cable and how is the slack defined? and which way should i turn the adjusting nut to get that better response?
http://www.clubsi.com/howto_throttle.shtml
Old Dec 14, 2002 | 09:53 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Righty - tighty, lefty - loosey.
Old Dec 19, 2002 | 01:47 AM
SlowB16ACRX's Avatar
SlowB16ACRX
in other words, make the cable tight
Old Dec 19, 2002 | 10:31 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You don't want it too tight. About 1/2" of deflection is fine.
Old Dec 19, 2002 | 07:30 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
Hey, how do you measure deflection?
Old Dec 19, 2002 | 07:55 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
It's the distance the cable moves before the throttle starts opening. Use a ruler.
Old Dec 19, 2002 | 08:36 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
so, to measure deflection on an alternator belt, I just pull on the belt and see how far I can pull it before the alternator turns?
Old Dec 19, 2002 | 09:13 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You usually measure deflection on a belt by twisting it. A half turn either way is usually good tension. They also make tools to measure deflection if you want to be precise, but for belts, I find the twisting method usually works well.
Old Dec 23, 2002 | 12:03 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
what belt are we talking about here? the timing belt or the throttle cable?
Old Dec 23, 2002 | 09:16 AM
z24hedturnr's Avatar
z24hedturnr
U want that Woo WOO
We just tightened it up til it was good and snug and there was NO slack in the line at all . . .it didnt make a HUGE difference but it gives a lil more response
