better throttle response?
Old Dec 23, 2002 | 01:13 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Originally posted by tokyoracer
what belt are we talking about here? the timing belt or the throttle cable?
I'm talking about any belt for any belt-driven device. Like an alternator, power steering pump, etc. The throttle cable is exactly that, a cable. If I was referring to a cable, I would have said "cable." KangaRod was asking about his alternator belt deflection, so that post was directed solely towards his post, and did not relate to your throttle cable question.
Old Dec 23, 2002 | 07:10 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
the weapon r throttle rotor improves your throttle response alot. and its only about 20-30 bux.
Old Dec 24, 2002 | 03:39 PM
ferrealb16's Avatar
ferrealb16
Originally posted by inspyral
You usually measure deflection on a belt by twisting it. A half turn either way is usually good tension. They also make tools to measure deflection if you want to be precise, but for belts, I find the twisting method usually works well.
is that what deflection is? damn, i always thought deflection meant the distance a belt, chain, or cable moves up and down. think about it, when you work on a motox bike or what not, you cannot twist the drive chain, you simply move it up and down, with a ruler to see how much movement it has up and down. i know im a newbie, but im not, get my drift?
Old Dec 24, 2002 | 05:14 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Belts twist and twisting is the preferred way to measure slack in a belt. True that the distance it moves from center is the amount of deflection, however, it is much faster [and more accurate] to measure belt tension by twist since belts naturally stretch, and you don't want them to have so much slack that they don't do their job, but not so tight that they just wear out. Generally 1/8th to 1/4 [90 degrees] of twist is correct on a belt. On a chain, deflection depends on application, but not the same rules as a belt since too tight or too loose means that the sprockets get accelerated wear, and sprockets are much more expensive than belts, which do not eat up pulleys.
-Harry
AIM: NDcissive
