B16A ass + B16B head???
I was just wondering if anyone has tried this yet? A B16A block mated with a B16B head? would it be just like puting the B18C5 typeR head on a B18C1? How hard is it to do that anyway?
No, it wouldn't be like that.
Umm the stroke and displacement of the b16b is the same as that of the b16a, so it's not destroked, and has the same piston to deck height. It has more domed pistons for higher compression, different valvetrain/cams, and a port job....but it's essentially the same head/block.
NO, not all B series engines have the same blocks. The B18's have a taller deck than the b16's. If you put a b16b head on a b16a block you have basicly a detuned CTR. The pistons dont have the same CR as CTR and the rods arent as strong. other than that with some minor exterior features its a CTR. It wont make the HP that a CTR does nor will it be as reliable at high revs. A great combo like that would be a b18c block with b16 rods and pistons and a B16b/b18c6 head. With the taller deck of the b18 you can get a longer stroke with the same revs.
