Jdm B16a, Usdm B16a??????????
Old Dec 18, 2002 | 07:09 AM
JAMSiR's Avatar
JAMSiR
Default Jdm B16a, Usdm B16a??????????
I'm about to buy a B16A engine and I would prefer it to be a JDM B16A with hydro tranny and lsd. Problem is, I don't want to be ripped off buying a USDM engine. Is there any way to tell apart a USDM one and JDM one. I heard about some things but they don't make quite any sense. If you have any info on B16As that would be really cool.
I also have another question, is it possible to put the B16A with a hydro trannny and lsd in a 4th gen hatch Si, because HAsport only sells mounts for the B16A with cable tranny.
Old Dec 18, 2002 | 08:47 AM
redheat86's Avatar
redheat86
DoriTen y0
it has been done. not sure on what mounts or pedal set you would use. usdm vs jdm, none really. only way yo tell block apart is the fact that a jdm will just list b16a and a usdm will list b16a2 for a obd2 motor or b16a3 for obd1 motor.
Old Dec 18, 2002 | 01:19 PM
JAMSiR's Avatar
JAMSiR
does the serial number under B16A reveals something too?????
Old Dec 18, 2002 | 07:40 PM
redheat86's Avatar
redheat86
DoriTen y0
most likely not, usdm wis youll be bale to see what car it came from. jdm you cant really use that for anything as you cant look it up.
Old Dec 18, 2002 | 07:55 PM
dantastic's Avatar
dantastic
cx power!
usdm should have a # stamped on the after the "B16A", like "B16A2" (usdm 99+ civic si) or "B16A3" (usdm delsol vtec). im pretty sure there isnt a hydro -> cable conversion kit. you best bet is an aftermarket lsd in a stock b16 cable tranny. there mite be a cable tranny with a factory lsd, but im not tooo sure
Old Dec 19, 2002 | 01:52 AM
SlowB16ACRX's Avatar
SlowB16ACRX
there is a b16a cable tranny that has lsd, it just hard to come by and the asking price is too much. i'm currently using the jdm s1, shorter gears. you planning on turbocharging the b16a? or going n/a?
Old Dec 19, 2002 | 10:15 AM
JAMSiR's Avatar
JAMSiR
turbo (or vortech supercharger) + nos is what I would like to do
Old Dec 19, 2002 | 06:41 PM
SlowB16ACRX
turbo loves long gear ratio
