next for turbo ex?
Old Dec 20, 2002 | 03:43 PM
TaylorC01's Avatar
TaylorC01
Default next for turbe ex
i just got my car back from the shop!!.. to refresh you memory i got a '97 turbo ex (sohc vtec) d16y8.. Tubonetics wastegate, hks manifold, garret t3, turbo xs type h BOV, intercooler, .. and i was just wanting to know what you guys think the next upgrade should be??.. everybody i've talked to so far says fuel... and so i ask what about it??. .. fuel injectors?, fuel rail,?? teach me the ways of good fuel for my turbo car...!!!
Old Dec 20, 2002 | 04:06 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You want to upgrade the fuel pump, definitely.
You also want to upgrade to higher flow rate fuel injectors. You can either get some RC 440 cc/min, or get used ones out of a turbo DSM for pretty cheap. To run the DSM injectors you'll need the injector harness and resistor box out of a non-OBD ('88-'91) 4-cylinder Honda.
From there you'll need a way to tune the thing. You can run an A'PEXi V-AFC with no sort of "hacks" by setting the fuel trim to around -35% across the board and then drive it to a dyno for tuning. That'll run like $300 plus tuning time.
Otherwise there is Hondata. An s100 w/ boost will run you $445. You will need to accquire an OBD-I ('92-'95) ECU preferably out of a VTEC car for Hondata to convert, and a harness to plug the OBD-I ECU into your OBD-II wiring.
Old Dec 20, 2002 | 04:09 PM
TaylorC01's Avatar
TaylorC01
ok.. let me get this straight.. i need to get a fuel pump and injectors... and then i need a way to tune them?.. right?
Old Dec 20, 2002 | 05:56 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Yes.
TaylorC01's Avatar
TaylorC01
k
Old Feb 5, 2003 | 05:20 AM
TaylorC01's Avatar
TaylorC01
will an obd1 resistor box work? instead on a non obd?... if not.. then why??
Old Feb 5, 2003 | 06:53 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The non-OBD Honda injectors have a much higher impedance (like 12 ohms I believe) than the newer ones which are like 3-4 ohms. The DSM injectors have similar impedance to the non-OBD Honda ones so you need a non-OBD Honda resistor box to match the resistance to the ECU.
Old Feb 5, 2003 | 07:05 AM
TaylorC01's Avatar
TaylorC01
i was just wondering cause i saw some 450cc dsm injectors on ebay w/ an obd1 resistor box for $150.. and was wondering if i should get it?..
Old Feb 5, 2003 | 07:27 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Actually, it's the other way around. Saturated injectors are high-impedance, and you need the resistor pack to make up for the peak-and-hold injectors' low-impedance. An ECM that was meant to run saturated injectors will be looking for that 10-12ohm impedance.
Old Feb 6, 2003 | 05:14 AM
TaylorC01's Avatar
TaylorC01
so do you think that's a good deal or not??
