94 b18C into a 98 teg question
Old Aug 31, 2005 | 02:15 PM
MOBSTER's Avatar
MOBSTER
Default 94 b18C into a 98 teg question
I'm putting a engine out of a 94 gsr into a 98 gsr body, I have most everything competed, but what appears to be some kind of vacume switch/sensor on the top of the intake manifold has a two wire connector comming from it and the wiring harness hass a three wire connector, what should I do? and is there anything else that you know of that I'm going to run into as far as not matching up?
Old Sep 1, 2005 | 04:09 PM
MOBSTER's Avatar
MOBSTER
Well, I figured some would have done this before.
