Compression
Old Jul 27, 2005 | 08:50 AM
hachacker5024's Avatar
hachacker5024
Default Compression
i need to know the compression (PSI) for a 91' 1.8L LS with 124,000mi on it
Old Jul 27, 2005 | 09:49 AM
mberndt's Avatar
mberndt
Don't understand your question??
U test your OWN compression with a guage...
There's no way to tell the compression on an engine with 124,000 miles unless u check it yourself...
U can find out what the compression should be when your engine is new, look in a haynes or chilton...
Or are u asking what the Compression RATIO is? if so, it's not rate in PSI.
Old Jul 27, 2005 | 10:12 AM
teg92's Avatar
teg92
WHAT OK YEAH!
9:2:1 is your compression ratio. if the Compression Gauge reads less than 150psi then you might have some problems anything above 175psi should be fine. Eash Cylinder should read about the same they could be a little off but if there off by 15psi then something is wroung. Someone Correct me if im wroung.
