D16Y8 Supercharge vs. K20
Old Aug 5, 2005 | 07:43 AM
PigPen209's Avatar
PigPen209
Default D16Y8 Supercharge vs. K20
I have a 96 Civic EX coupe with the D16Y8 engine. I wanted to supercharge it with a Jackson Racing blower until my brother recommended a k20 motor swap. I did some research and found that the blower would give about 142hp and the k20 motor 200hp stock. Of course im looking for more power for less money and they both should cost about $2000+. So does anyone recommend either of these options.
Old Aug 5, 2005 | 08:01 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Unless you have a good deal of mechanical experience, I'd go with the JRSC. The K20 swap is not a quick-and-easy thing.
Buy a greddy turbo kit. It's cheaper than the JRSC and much more flexible. :yes:
Old Aug 5, 2005 | 08:39 AM
95civiclx's Avatar
95civiclx
HMT b7
yeah, piece together a turbo kit, even running low boost (6-7 psi) you should break 150 hp easily. you could do a used/junkyard setup for around 1000, or even a decent kit for 2500. i would never personally supercharge a car unless it was already making decent power N/A. its too much money and you dont see decent results out of a car thats only making 125 hp. you are paying over 2 grand, for less than 20 hp. and all the k20's ive seen were a bit more than 2000,
but to answer your question.....k20 or a supercharged d16.................go with the k20.
if you start wondering about the turbo....go to www.turbod16.com and download some of the videos there. a stock d16y8 with 9 psi... making like 186 whp, and 170 ft lbs of torque, and that would probably cost the same or less than the supercharger, and definetly less than the k20.
Old Aug 5, 2005 | 01:35 PM
b16ahybrid's Avatar
b16ahybrid
You could build your d16 and buy a turbo for the cost of swapping in a k20. I just finshed doing a k20 into an eg and it was a pain in the ass, but well worth the effort (cost I would disagree with)....the k20 run over $3k then you have about another $1500 in parts (axles, mounts,etc)
A stock d16 can handle about 220whp with a turbo, and close to 400whp with rods and pistons.
Old Aug 13, 2005 | 09:49 AM
PigPen209's Avatar
PigPen209
I considered the turbo before (might go with it now) but realized that the D16y8 is not really a good motor to build off of. So I guess the supercharger is outta the question, but now which is better - K20a swap ( yes i have the experience) or the turbo setup?? Also I saw the $850 turbo kits on eBay and assumed they are low quality - would anyone recommend those?
Old Aug 13, 2005 | 11:33 AM
kenton's Avatar
kenton
Change sig? Lose [quote]!
That's probably the intercooler-less OBX kit ahaha WEEE LETS SAFELY PUSH 2PSI
Old Aug 13, 2005 | 12:24 PM
Snoopy's Avatar
Snoopy
been there done that
i would recommend one of these if you want a subpar kit with components you will eventually have to replace anyway.
Old Aug 13, 2005 | 03:24 PM
Paulll's Avatar
Paulll
Hail Bent
i would h:
Old Aug 13, 2005 | 04:41 PM
95civiclx's Avatar
95civiclx
HMT b7
ssautochrome....where the housings are bonded together with epoxy....thats quality
Old Aug 13, 2005 | 08:14 PM
b16ahybrid's Avatar
b16ahybrid
lol, you saw that too.
IMO I would never buy any e-bay "kit" unless it was a known mane brand such as revhard, drag, or greddy (although I'd never buy a greddy kit, power output is to minimal for my taste)...
You can build your own kit for less money then a k20 swap and still beat it (performance wise) the d16 is a great motor to turbo and makes good number in stock form.
Don't get me wrong, the k20 swap in the eg looks awesome and performs great, but the cost per reward is kind of out of balance IMO. If you want maximum performance with a stock motor then the k20 is your engine. If your looking maximum performance with a modified engine then a boosted d16 is your best bet.
I can tell you from experience, the k20 swap is a pain in the ass. Sure they make swap kits, but it's still a pain in the ass to get everything to fit correctly...it's still not a bolt-in swap....it's takes some work still
