B16A ignitor.
Old Sep 1, 2005 | 06:04 AM
psx_pat's Avatar
psx_pat
Default B16A ignitor.
Is it B16A ignitor (little brown/black box inside the distributor) is the same or at least similar to D16 ignitor? Cause I think my ignitor have a problem but is really hard to find B16A ignitor in here (I don't live in the US). So if anyone know or have any suggestion let me know. Thanks.
Old Sep 1, 2005 | 12:51 PM
servion's Avatar
servion
I *think* all the D/B/H honda ignitors are the same
Old Sep 1, 2005 | 03:40 PM
qtiger's Avatar
qtiger
What a coincidence. Guess what I worked on today. h:
I'm sure the ignitors themselves are the same, the little aluminum brackets on the back of the ignitor are different. Just re-use the old bracket.
Oh, and have fun with those two 7mm bolts on the right side of the distributor.
Old Sep 2, 2005 | 05:04 AM
psx_pat's Avatar
psx_pat
Ok,thanks for the info.Cause when I rev my car at Wide Open Throttle during idle,kind of bogging between 1-3K rpms and after that is fine.I play little bit with my fuel pressure from 28-38psi still doesn't make any difference.Could it be bad ignitor?
Old Sep 2, 2005 | 05:06 AM
psx_pat's Avatar
psx_pat
I meant rev my car at neutral.
Old Sep 2, 2005 | 09:07 AM
qtiger's Avatar
qtiger
Does it idle okay?
Old Sep 3, 2005 | 01:15 AM
psx_pat's Avatar
psx_pat
It idle okay.But once in a while after I use the car for a while (20 minutes or so) and the temperature is hot the idle of the car is kind of bogging little bit (every 5 or 6 seconds the exhaust make a liitle bang noise) seems like misfiring or something.But only when the engine is hot.When I have MSD SCI ignition is even worst,sometime the engine is shutdown when the temperature outside is hot and the load is heavy.But after I took MSD SCI off this the only problem I have.Anyone know what cause it?Thanks.
