Best turbo for my application
Old Aug 9, 2005 | 10:17 AM
mberndt's Avatar
mberndt
Default Best turbo for my application
Hey guys,
I've been boosting now for 2000 miles, and my car works great...
Problem is, I've got a small turbo (T25), and it sucks at high rpms...
It boosts great around town, but above 5000 rpms in VTEC, u can feel the power fall off, and closer to redline, it makes almost no boost, and it's really not much of an increase if any over having it all-motor ...
I bought a TSI kit, because I didn't want to spend $3000 on a Greddy turbo kit, and there was pretty much no other choice for $1500. I knew about the difference between large and small turbos when I bought the kit, but I figured I'd still have more HP than I started with, but it seems this is not the case...
I have a B16A with GSR head, what is the best turbo that I can get??
I've been researching the different compressor maps, and I believe a T3/T04E turbo with a 57 trim compressor wheel will work best, flowing more than enough airflow at 8000rpms. Does anyone have any advice as to what turbo I should get.
Also, my bro is parting out his VR4 and I can get his td04-14b for like $125
I've seen the compressor maps for this turbo, and it doesn't flow as much as a T3/T4, but it's a Hell of a lot cheaper...
So, is it worth it for a 14B? Anyone running a 14B on a DOHC VTEC motor?
Thanks
Old Aug 9, 2005 | 02:41 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
Vtec should help that turbo keep its boost sure it'll fall off but still. t3 shoudl be fine.. nothing bigger..
Old Aug 9, 2005 | 03:49 PM
ValleySyder's Avatar
ValleySyder
even with vtec a 14b is not worth it at all .. believe me , i know a few guys running it .. and they all want a major upgrade .. your better of with the T25
Old Aug 9, 2005 | 07:39 PM
b16ahybrid's Avatar
b16ahybrid
Originally Posted by mberndt
Hey guys,
Thanks
Coming from personal experience the only t3 that I would run on a b-series is a t3 60-1.
The t3t4 you listed is a big I mean BIG upgrade from the turbo you have now.
I went from a strait t3 (.42 cold .48 hot) to my current t3t4 (.57 trim .63 a/r). What a night and day difference. Unless you have experinced a turbo this size or larger on a b-series, you won't appreciate the power.
I ran that t3 for about 2 years and I thought I was content. The first day with the new turbo, I about pissed my pants..lol. I would NEVER recomend anything smaller for a b-series, street car.
My power went from 199whp to 248whp by swapping turbo's, AND running 1psi LESS. I made 199whp (with the boost dropping off once vtec hit like your experiencing) @10psi with the t3 and 248whp with the t3t4. I dropped my quarter mile time from 13.54 down to 12.42 (12.7 with the same tires).
save yourself the headache and get a turbo that will flow enough for your motor, your bro's turbo's are to small.
BTW the turbo would spool about 2k rpm and have full boost by about 3,500rpm (9psi) and 13psi by about 3,800rpm.
Old Aug 11, 2005 | 05:09 AM
mberndt's Avatar
mberndt
Hey,
Great info, thanks alot...
Well, I'm guessing that putting on my Bro's 14B would be sort of a headache, being that I have the entire kit that's designed for the T25, it would prob require some modification...
And that was my same thought, I want to get the turbo that flows the absolute best for my application, prob is I don't have another $800 for a new one, and I'm getting very angry searching on EBAY because everytime u look for a QUALITY used turbo for like $400 goddamn stupid SSAUTOCRAP comes up all over the screen , lol
Thepartstrader used to be good, but now everything is located in Cali.
What about a Mitsu 16G or 18G (like one that comes with Greddy kit for GSR)
maybe I could find a used one on DSMtrader or VR4.org
Rebuilding is no prob, I could have my bro do it...
So I'm guessing the T3/T4 with a 57 trim is best right? seems people make the most hp with those setups.
Can anyone gimme a good link for detailed specs on exhaust flanges and such... I want to know what plate/welding I must get to mount a T3/T4 on my manifold.
Thanks again.
Later
Old Aug 12, 2005 | 01:08 PM
Paulll's Avatar
Paulll
Hail Bent
gt35 with or without the r,
the end
