zc help
Old Sep 5, 2005 | 06:49 PM
higguns's Avatar
higguns
Default zc help
ok so today i installed my zc and hooked everthing up. i go to start it and it starts on and off shaking and then stalls. we figure the distributor to be the problem, so we take it off and clean the points and the contacts and swap the coil from my d-series. put it back in and wire it up and go to start it and it starts but struggles. so i narrow it down to the fuel filter which we decided to use the one that came with the engine (jdm cuz it had jap writing on it). we take it off and the gas inside it is all discoloured so we put the one from my d-series on and starts up but still shakes so we rev it abit... at the most we went to 6000 rpm and it clears up, but then rite after it clears up it starts making a knocking type sound from the engine. the engine runs fine now and idles perfect, everything is fine except for the knocking noise. heres things i did to the engine/trans before i put it in: installed my crx si flywheel with a new clutch, replaced throw out bearing, swapped my crx oil pan cuz the zc one was dented, replaced oil pan gasket, installed new spark plugs, ported out my exhaust manifold to match the zc. my friend is an anprentess mechanic and said he cant figure it out cuz the engine idles pefect, but it makes a knocking sound and there are no codes. he said it sounds like theres something loose inside or something. i'm getting really fustrated and need your help, is this engine fucked or can anyone tell me whats wrong. i've been without a car now for a month adn i'm getting really fustrated.
Old Jun 3, 2020 | 05:10 PM
90ZCivic's Avatar
90ZCivic
I put a zc in my civic and now have a knocking noise when its cold, sounds to me like the gudgeon pin, maybe lower rod knock though, not sure its a little engine, hard to tell when u been messing with 350 chevy's and such forever, I'm thinking lower rod, sounds like mine is coming from next to the flywheel, when I put the zc in the civic it started and ran like shit till I cleared it up also and I also have a dent in the pan but haven't put my d15 one on yet cause it doesnt look too bad but I drove mine bout 3000km now and I just started noticing the knock a few days ago, hope the pan aint messing up oil to pickup flow... and hope u get yours figured out for cheap, I'm hoping to find a bad bearing in the bottom of the rod cause theres good ods of a cheap fix aslong as the crank journal isnt gualged or out or round. pray the crank and pistons are good!! I'll post what I find
90ZCivic's Avatar
90ZCivic
omg that post is old hahahah
941crx
CRX & Pre 92 Civic
65
Jan 22, 2010 09:39 AM
nexgen91
CRX & Pre 92 Civic
Nov 6, 2006 10:36 AM
higguns
CRX & Pre 92 Civic
4
Sep 6, 2005 04:19 PM
honura
CRX & Pre 92 Civic
10
May 31, 2005 02:16 PM
craig5_12
May 1, 2005 08:20 AM
