GSR tranny making noise??? [B18C1 in 96-00 Civic]
Old Aug 17, 2005 | 04:37 PM
dawrenn's Avatar
dawrenn
Default GSR tranny making noise???
I have a 99 civic with a GSR swap. When the car is on and my foot is off the clutch pedal there is a wierd noise coming from the tranny, When I put my foot on the clutch the noise stops. My dad says its the throw out bearing. I was wondering what will happen if I dont replace it? If I have to replace it how hard will it be to replace?
Old Aug 17, 2005 | 08:11 PM
DakarM's Avatar
DakarM
are you sure the tranny didn't come with a lightened flywheel. lightened flywheel will sound like there is marbles in the tranny when the clutch is not engaged. the sound goes away completely when the clutch is engaged.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Aug 17, 2005 | 08:30 PM
dawrenn's Avatar
dawrenn
The clutch and flywheel is a Competition Clutch O.E. spec clutch kit, The shop that did my swap was also suppose to replace the throwout bearing but I am not sure if they did.
What you described is exactly what is happening.
Old Aug 18, 2005 | 07:09 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Take it apart and look...
Old Aug 18, 2005 | 07:57 AM
dawrenn's Avatar
dawrenn
What should I look for?
Old Aug 18, 2005 | 08:42 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Is it a whining noise? If so, it is your throwout bearing.
They either forgot to lube everything down there, or didn't even bother changing it at all.
Old Aug 18, 2005 | 08:52 AM
dawrenn's Avatar
dawrenn
Yes it is a whining noise. I really hope it is the throwout bearing.
I do think they just did not bother changing it.
Old Aug 18, 2005 | 08:56 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
How do you expect to diagnose this any further over the internet?
Take the car back to the people who did the work and ask them about the noise. They have every reason to answer your question about the throwout bearing honestly.
The Hybrid forum is the place for your questions.
Old Aug 18, 2005 | 10:25 AM
dubcac's Avatar
dubcac
I
It's your throwout bearing. It probably wasn't properly lubed. Unless you need to replace the clutch, I wouldn't bother.
Old Aug 18, 2005 | 10:40 AM
dawrenn's Avatar
dawrenn
Good. Why would it need to be lubed when its sealed? A few people I havew talked to said there is no point in lubing it. My dad said if the throwout bearing is not replaced it will eventually seize up the transmission.
