GSR tranny making noise??? [B18C1 in 96-00 Civic]
Old Aug 18, 2005 | 12:08 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
So.. take it apart and replace the pilot and throwout bearing. Overanalyzing owns you.
Old Aug 18, 2005 | 12:10 PM
dawrenn's Avatar
dawrenn
Does the tranny have to be taken apart to replace the pilot bearing? If so I am just going to send the tranny back and get another one.
Old Aug 18, 2005 | 12:23 PM
westcoaststyle
Dude, holy cow...
Read: http://auto.howstuffworks.com/clutch1.htm
Pilot bearing is in the center of the flywheel and the transmission shaft tip rests in it. The throwout bearing pushes on the pressure plate to engage the clutch. It's all between the engine and the tranny as part of the clutch assembly.
Old Sep 1, 2005 | 09:34 AM
Techme06's Avatar
Techme06
Eg b20b turbo
hum. . just leave everything where it is and have a buddy help you take it apart to see what's wrong. i'll take some time and it's not simple. should change the clutch while your in there = )
Old Sep 1, 2005 | 09:53 AM
dawrenn's Avatar
dawrenn
The clutch and flywheel are new. It did not make the sound until those were replaced.
Old Sep 9, 2005 | 08:15 AM
JETSPD1477's Avatar
JETSPD1477
O RLY?
take it apart already. posting in some forum isn't going to fix it. the only way you're going to discover the problem is by taking it apart. check to make sure the throwout bearing spins smoothly and that the pressure plate and flywheel are bolted in properly.
